Solwise 85mm ADSL Filter
Available while stocks last
ADSL Filtered BT Faceplate. Integrates an ADSL microfilter into a standard BT socket. Although supplied with a surface mount back-box for convenience, the faceplate is replacement compatible with existing BT extension sockets. Connections are provided at the rear to enable further ordinary extensions to get a filtered or unfiltered signal. This device is available in two sizes: The 65mm version is compatible with a standard BT extension socket. The 85mm version matches the standard electical socket of the type used with plaster/board mount back-boxes.
  • Model: ADSL-FFP85
  • Shipping Weight: 0.8 kgs
  • Manufactured by: Solwise
£5.26 Ex VAT
