SSP
Displaying 1 to 12 (of 70 Products)
EXT800
SSP
(image for) Midi monitored stainless steel weatherproof maglock 12/24Vdc
This midi stainless steel external maglock is ideal for outdoor use (e.g. pedestrian gates) due to its weatherproof construction and attachment for...
£109.99 Ex VAT
Add to Cart
MF4
SSP
(image for) Mifare MF 4K ISO Card
Printable white colour 4K ISO card Details ISO card printable White colour 4K
£1.33 Ex VAT
Add to Cart
SPB001A
SSP
(image for) Secware Architrave Exit Button
Architrave Plastic Request to Exit [RTE] Switch Includes standard UK architrave patress SPB001A is a narrow, architrave push to exit button for...
£12.00 Ex VAT
Add to Cart
DL450
SSP
(image for) SSP DL450
SSP DL450
Armoured door loop surface mounted, aluminium end caps
£14.00 Ex VAT
Add to Cart
M1SAF
SSP
(image for) SSP M1SAF mortice electric release, 12V AC/DC, fail safe
European style mortice electric release, 12V AC/DC, fail safe Technical specification: Dimensions, strike 90 x 28 x 20mm Dimensions faceplate 158 x...
£15.92 Ex VAT
Add to Cart
EM07
SSP
(image for) SSP Midi Magnetic Lock monitored
Midi Magnet, Surface Mount, Monitored, Standard Fixing 12V/24VDC. Voltage Tolerance: 15% Current Draw: 500mA @ 12Vdc 250mA @ 24Vdc at...
£76.11 Ex VAT
Add to Cart
R1SAF
SSP
(image for) SSP R1SAF Fail Safe Rim Release
Rim release fail safe Details Euro style release Fail safe 12Vac/dc Rim fitting Outward opening rim release option
£25.69 Ex VAT
Add to Cart
EM20
SSP
(image for) SSP 1200Llbs Monitored Mag Lock
Alternative product CLICK HERE Key Features Lock monitoringDual voltageSurface mountSilver with anodised aluminium12vDC current consumption,...
£74.00 Ex VAT
Add to Cart
M1SEC
SSP
(image for) SSP 12Vac Euro Mortice Release Fail Secure
Euro style electric release (strike) supplied with long face plate. This fail-secure version is suitable for use with ac current only. Recommended...
£12.73 Ex VAT
Add to Cart
R1SEC
SSP
(image for) Ssp 12Vac Euro Rim Release Fail Secure
Euro style electric release (strike) with fixed jaw supplied with rim case. This fail secure version is suitable for use with ac current only....
£14.88 Ex VAT
Add to Cart
2MTL
SSP
(image for) SSP 2 metre adjustable L bracket for EM-AH2 and EM-AH10-2 ranges
2 metre adjustable L bracket for EM-AH2 Details Adjustable 2000(L) x 63.5(W) x 38(H)mm Suitable for use with both slim and standard housings ...
£48.12 Ex VAT
Add to Cart
EM-AH10-2
SSP
(image for) SSP 2 Metre Standard Architectural Housing 1 Cut Out
Standard architectural housing for installation above a single doorway that is wider that 1 metre where a single maglock with up to 545kg holding...
£136.12 Ex VAT
Add to Cart
