Takex External 12m Pet Tolerant PIR Single Head
DUAL ZONE system
This sensor is equipped with a DUAL ZONE system which initiates an alarm only when detection occurs in both horizontal and down ward zones simultaneously. No alarm signal is given if only one zone is activated by small animals, vehicles etc
Various detection patterns
Perimeter, window or wall detection can be made by adjusting detection zone with area masking sheet. MS-12FE equipped with two sensors can cover two perimeters or windows by itself.
Rain Proof Housing
Rain-proof structure facilitates outdoor installation. Various mounting position such as wall and pole can be chosen.
Sensitivity adjustment
Sensitivity can be adjusted between 30% and 170%.
Detection system Passive infrared
Coverage When horizontal detection Angle : 90° Detection distance : 40' (12m) Horizontal zone : 7 zones Downward zone : 7 zones
Coverage adjustment 7 zones 2sets of MS-12TE sensor Horizontal : ±90° Detection distance : 6.6' to 40' (2 to 12m) (By adjusting vertical angle of downward zone)
Supply voltage 12 to 28V DC (non-polarity)
Current consumption 35mA MAX.
Alarm output Dry contact relay output N.C./N.O. selectable Contact capacity : 30V (AC・DC), 0.25A MAX. (Resistive load) Contact operation : Detection time + off delay(2sec)
Tamper output Dry contact relay output N.C. Contact capacity : 30V (AC/DC), 0.1A MAX. (Resistive load)
Operation LED Red LED Blinking at warming up (LED disabled) Lighting at alarm (LED disabled)
Pulse count settings once / three times (with a switch)
Sensitivity adjustment Approx. 30% (L) - Approx. 170% (H) (By potentiometer)
Connection Terminals
Ambient temperature -4°F to +122°F (-20℃to +50℃)
Mounting position Indoor / Outdoor
Weight 13.7oz (390g)
Appearance Body : AES resinLens : PE resin
Accessory Tapping screw : 2 Area masking sheet : 1
White lens options available
  • Model: MS-12TE
  • Manufactured by: Takex
£102.36 Ex VAT
