Texecom Odyssey X-E Grade 2 Back Plate
Introducing the Odyssey XB External Sounder – the ultimate solution for your security needs. With its advanced features and functions, it delivers superior performance, functionality, and flexibility. In this article, we will explore the key features and capabilities.
Photo Quality Customer Branding
The Odyssey X is the perfect solution for installers and distributors who want to enhance their brand image. With photo quality custom-designed graphic inserts, you can showcase your brand with high-quality graphics that are weatherproof, fade-proof, and waterproof. Plus, there’s no minimum order quantity, and the product is always available at distributors, making it easier for you to get what you need when you need it.
Illuminated Backlight Options
The Odyssey X-B backlight options offer the most accomplished illumination experience, ensuring your logo gets the presentation it deserves. Illumination LEDs, integrated into the backplate module, provide the highest quality illumination combined with rugged weatherproof design and installer-friendly features.
115dB (A) Twin Piezo Sounder
The Odyssey XB’s twin piezo sounder produces an impressive 115dB (A) output, ensuring that any intrusion attempt will be heard loud and clear. Additionally, the alternating white LED indication offers a visual alert to potential intruders.
Advanced Security Features
The Odyssey XB features wall and cover tamper, battery monitoring with fault output, and patented engineer hold-off mode. With these advanced security features, you can be confident that your property is protected.
EN50131-4 Compliant
The Odyssey XB is EN50131-4 compliant and Grade 3 Class IV certified, meeting the highest security standards. With its rugged design and advanced features, the Odyssey XB is the perfect solution for any security application.
In conclusion, the Odyssey XB External Sounder is a reliable, rugged, and advanced security solution that offers superior performance, functionality, and flexibility. With its photo-quality customer branding, illuminated backlight options, and advanced security features, we think it’s the perfect solution for any security application.
  • 115dB (A) twin piezo sounder
  • Wall & cover tamper
  • Patented engineer hold-off mode
  • Battery monitoring with fault output
  • Alternating white LED indication
  • Grade 3 Class IV
  • Part code WDC-0002
WIRED UNITS
Supply Voltage:12-16 VDC (13.7 nominal)
Current Drain (typical at 13.7VDC):
Quiescent18mA +40mA (Backlit version)
Strobe100mA
SounderSABLCSCB
X-E:285mA160mA30mA
X-BE:325mA200mA70mA
X:405mA190mA30mA
X-B:445mA230mA70mA
Standby Battery :
Type:NiMh Stack
Voltage:7.2VDC (nominal)
Capacity250mAh
Flash Tube:1Ws Xenon
Comfort LEDs:
Brightness:100mcd (typical)
Flash Rate (tamper secure):1Hz alternating (typical)
WIRELESS UNITS
Supply Voltage:12V DC
Battery Type:8 x Lithium type (AA 1.5V)
High Power LED Strobe:320lm
Comfort LEDs:
Flash Rate (tamper secure):1/4 sec flash at 5 sec intervals alternating (typical)
Wireless Frequency:868.0MHz - 868.6MHz
ENVIRONMENTAL
Volume (SAB mode at 13.7 VDC):
X-W:105dB(A)
X-E & X-BE:109dB(A)
X & X-B:115dB(A)
Acoustic Output:Varying Sound Output
Cut-Off Time:15 minutes
Waterproof Coating:Conformal
Operating Temperature:-25°C to +55°C
Storage Temperature:-25°C to +60°C
Odyssey X1 Part Numbers
ODYSSEY X COVERS
WDA-0001Odyssey X1 Cover (White/Blue)
WDA-0002Odyssey X1 Cover (White/Red)
WDA-0003Odyssey X1 Cover (White/White)
WDA-0007Odyssey X1 Cover (White/Green)
WDA-0004Odyssey X1 Cover (Black/Blue)
WDA-0005Odyssey X1 Cover (Black/Red)
WDA-0006Odyssey X1 Cover (Black/White)
WDA-0008Odyssey X1 Cover (Black/Green)
ODYSSEY X ELECTRONIC OPTIONS
WDC-0001Odyssey X-BEGrade 2 Sounder with Integral Backlight
WDC-0002Odyssey X-BGrade 3 Sounder with Integral Backlight
WDD-0001Odyssey X-EGrade 2 Sounder
WDD-0002Odyssey XGrade 3 Sounder
WDE-0001Odyssey X-DDummy Sounder
GBV-0001Odyssey X-WWireless Sounder
  • Model: WDD-0001
  • Manufactured by: Texecom
£23.55 Ex VAT
