8000 Series Access Control Modules
Coded access and Vprox proximity modules are available for the 8000 Series range:
8800 – 2 code, 2 relay output coded access module with push to exit inputs. Both relays are programmable between 1-99 seconds or latching. Codes can be 4-8 digits long.
8900- 100 code, 2 relay output coded access module with push to exit inputs. Both relays are programmable between 1-99 seconds or latching. Codes can be 4-8 digits long.
8849 – Proximity reader module suitable for all Vprox systems. It has a yellow standby led, green “fob/card accepted” led and red “not valid led. This reader must be fitted within 50 metres of controller and requires 5 connections.
The standard front plate is stainless steel (/S) or available in matt aluminium (/A).
- 2 code or 100 code access control keypads for the 8000 Series including 2 dry contact outputs and 2 push to exit inputs
- Vprox proximity module for the 8000 Series including audible and visual indication
Technical Details
8800 & 8900 Codelocks:
- Input voltage – 12-24V AC or DC
- Power consumption – 2VA
- Storage capacity – 2 codes (8800), 100 codes (8900)
- Code length – 4 to 8 digit
- Relay time – 1 to 99 seconds or latching
- Relays – 2 (C, NO, NC)
- Relay contacts – 24Vac/dc @ 3A
- Push to exit inputs – 2
Product Variants
- VX8800 – 2 codes, 2 relays codelock module
- VX8900 – 100 codes, 2 relays codelock module
- 8849 – Proximity reader module
