Videx Extension Sounder For Vx2200 System
Extension sounders available for the whole Videx range:
512D – Extension sounder for the VX2200 2 wire BUS system in a wall mountable white ABS plastic box..  The unit has an 8 way Dip-switch to program the address of the device.  Up to 3 units can be addressed with the same number.  The call tone is different according to the origin of the call (Main entrance call or local door bell).  Volume is adjustable using a 2 position jumper.
  • Extension sounders for a range of Videx systems
  • Wall mountable plastic enclosure
Technical Details
512D:
  • Systems – VX2200
  • Dimensions – 110mm(L) x 70mm(W) x 30mm(D)
  • Mounting – Wall
  • Material – White ABS plastic
Product Variants
  • 512A – Extension sounder (45ohm)
  • 512E – Extension sounder with tone generator
  • 512R – Extension buzzer (12Vac)
  • 512D – Extension sounder (Vx2200)
  • Model: 512D
  • Manufactured by: Videx
£38.67 Ex VAT
