Videx Modular 8000 series 4 button module
As a direct result of the overwhelming success of the 4000 Series, Videx have remodelled and improved the popular 800 Series and introduced, as its replacement the Videx 8000 Series.
The Videx 8000 range of modular push button panels allows the installer or end user to customise the appearance of the out door station in an easy and cost effective way dictated by the requirements of the installation.
The 8000 modules are assembled into supporting frames (which can be flush or surface mounting) and are available to house from 1 to 9 modules. Full electrical and mechanical compatibility has been retained, most of the 8000 Series modules have the same terminal configuration as the 800 Series and all modules in the 8000 range will fit the 800 series supporting frames.
The re-designed 8000 Series incorporates mechanical improvements for improved weather resistance and up-dating of the electronics for more reliable operation in harsher environmental conditions.
The remodelled 8000 Series front supports, rain-shields and surface mounting units are available in a range of finishes.
The 8000 Series modular entrance panels are fully compatible with the older 800 Series both mechanically and electronically. They benefit from a more modern design with the frames available in an aluminium or black finish and the modules in a mirror finish stainless steel or matt aluminium finish.
Four call button module with name plates [Dimensions 97mm(W) x 120mm(H) x 29mm(D)]
  • Model: 8844/S
  • Shipping Weight: 0.3 kgs
  • Manufactured by: Videx
£28.99 Ex VAT
