Videx Surface 800 2 Code 2 Relay Stand Alone Code Lock
OBSOLETE - Alternative Click Here
800NS, Videx, Surface Stainless Steel Keypad - 2 Codes + Light or Ali (21PS)
Stainless steel surface mounting coded access keypad with rainshield. It has 2 codes and 2 relay outputs with a PTE input on the first relay. Both relays are programmable between 1-99 seconds or latching. Requires 12-24v ac/dc psu.
Specifications:
  • Material: 12 Gauge 304 grade stainless steel
  • Dimensions: 103mm x160mm
  • Number of codes: 2
  • Number of relays: 2 dry contact (24V 5A max)
  • Inputs: 2x PTE inputs for relay 1 & 2
  • Code length: 4-8 digits
  • Power: 12-24Vac or dc (2VA)
  • Programmable relay times: 1 to 99 seconds or latch
  • Model: 800NS
  • Shipping Weight: 1.2 kgs
  • Manufactured by: Videx
£120.11 Ex VAT
