Vimpex
Displaying 1 to 9 (of 9 Products)
HSCP-S-2
Vimpex
Vimpex
Vimpex HYDROSENSE 2 ZONE CONTROL PANEL ONLY
Hydrosense The Hydrosense Water Detection System is designed to protect areas where water leakage could seriously damage electrical, communication...
£240.96 Ex VAT
Add to CartHS-HWCK1
Vimpex
Vimpex
Vimpex HS-HWCK1 Hydrowire Conversion kit
HS-HWCK1 Conversion kit for replacing an old section of Hydrowire *Both kits supplied from image Hydrowire Conversion Kit. For replacing old 5m...
£35.95 Ex VAT
Add to CartDH/CHO
Vimpex
Vimpex
Vimpex Keeper Plate with Extension Chains and Rubber Rings
The Chain Keeper enables a wall mounted electromagnetic door holder to be used even
£43.18 Ex VAT
Add to Cart5PCL101
Vimpex
Vimpex
Vimpex UGO Reset Call Point Engineers Tool
The UGO Reset, the ‘Swiss army knife’ of call point test and reset keys for fire alarm systems. The UGO reset keeps the keys that fit...
£36.95 Ex VAT
Add to CartK1601/E
Vimpex
Vimpex
Vimpex HYDROSENSE PANEL 1 ZONE
OBSOLETE - Alternative Click Here Hydrosense The Hydrosense Water Detection System is designed to protect areas where water leakage could...
£197.00 Ex VAT
... more infoK2105
Vimpex
Vimpex
OBSOLETE - No longer available Hydrowire Available as standard 5 and 10 metre lengths, Hydrowire is a flexible cable which will continuously...
£78.96 Ex VAT
... more infoK2104
Vimpex
Vimpex
£64.56 Ex VAT
... more infoK2110
Vimpex
Vimpex
Vimpex End of Line Plug for Hydrowire
OBSOLETE - No longer available Each zone of Hydrowire is plugged into a Connection Box (K2106) and terminated by an End of Line Plug (K2110)...
£9.00 Ex VAT
... more infoK2101
Vimpex
Vimpex
Vimpex Floor Mounted Probe (Point Detection)
OBSOLETE - No longer available Point detection is provided by Floor, Drip Tray Probes and Float Switches - all connected to the control panel...
£60.00 Ex VAT
... more infoDisplaying 1 to 9 (of 9 Products)
